Premiere Pro starts rendering but then stops
  • January 10, 2021
  • 750 views
I have no idea why it happens or even know how to fix it. I have looked up so many videos and looked at other posts all to no avail. When using Premiere, I would finish editing a video I made and then I go into export settings and choose a custom made export file for the software to use. I use CUDA and I have maximum bit depth on but not quality. I also have memory set to memory and not performance, and yet when the rendering starts, it goes on for a couple of seconds and I also noticed that the time for rendering goes up instead of down. Once it goes up a little bit, the blue bar starts but never continues and when I click cancel after four minutes of waiting, Premiere crashes and I don't know how to fix or even prevent this. Any help would be greatly appreciated!
dominikkutrowski
Hello Zach,
I can't provide a solution for this, but I have the same problems. So it would be nice to get an answer from the Adobe team as soon as possible...
Which version of Premiere Pro do you use, currently?
Zach0101Author
I use the current version, v - 14.7
Zach0101Author
Oh, sorry man. I am on PC.
So, running as administrator might make it work?
