adam michelr57363792
Jul 6, 2019 12:07 PM UTC
premiere pro technical problem
I downloaded premiere pro on my computer and it runs so slowly and gets stuck each few seconds. If someone could please write me the criteria for a computer in which I would be able to use premiere pro normally, without the application getting stuck - It would be wonderful. Thank you.
    Jul 6, 2019 3:48 PM UTC
    Check out Step 4 below.
    Unofficial Premiere Pro Troubleshooting Guide
    Peru Bob
    Jul 6, 2019 2:41 PM UTC
    The minimum requirements will allow it to run, but how well it runs will depend upon not only the computer specs, but the media and effects and transitions used.
    Please use the free MediaInfo and post a screenshot the properties of your media in tree view:
    MediaInfo
    Averdahl
    Jul 6, 2019 12:48 PM UTC
