Premiere Pro timeline freezes when audio is imported
  • March 9, 2020
  • 4 replies
  • 6918 views
Hi there,
I have a very weird issue. When I import audio (mp3 in this case), the timeline would just freeze. I can't scroll around, I can't play anything back and there's a slight static noise. When I delete the audio file from the media directory, everything goes back to normal.
Also, as soon as I leave the register where the audio is and go to a different tab (e.g. Media Browser or Library), everything goes back to normal. It works just fine as long as I'm not in the folder where the audio file is. I've tried multiple audio files and they all lead to the same issue.
I've tried updating Premiere to the latest version, didn't fix it. Here are my PC specs:
- Windows 10 Professional
- Intel Core i7-8700K
- Asus Prime Z370-A
- GTX 1060 6G
- 16 GB RAM
I need help, please...
    Correct answer Peru Bob
    It's usually best to convert mp3 to wav before importing into Premiere Pro.
    Try resetting the preferences:
    https://community.adobe.com/t5/Premiere-Pro/FAQ-How-to-reset-trash-preferences-in-Premiere-Pro/td-p/8236158
    Reset a workspace
    1. Do one of the following:
    • Click the Workspace menu icon and select Reset to Saved Layout.
    • Choose Window > Workspace > Reset to Saved Layout.
    from here:
    Was having the SAME issue and resetting the workspace worked like a charm! THANK YOU!!!
    thanks for posting.  will hopefully help other people with the same problem
    Annmarie lawler
    I've tried the suggestions and am still having the problem - any more tips?
    and generally 48k 16 bit aiffs or wavs are ideal.
    I've converted the files to .wav now. Thanks for the tip!
    Peru Bob
    Reset a workspace
    from here:
    Resetting the workspace actually solved the issue. Thanks!
