Premiere Pro unable to load third party audio plugin
  • April 19, 2020
  • 13 replies
  • 21992 views
Dear Community,
I have Premiere Pro CC 2019. I can't get Premiere Pro to open as it always ends up showing the error message: 'Premiere Pro is unable to load third party audio plugin...'. I have checked that the related folders in Library have 'read and write' priviledge. What else can I do to fix this problem please? Do I need to download audio plugin? or do these plugins come with the programme itself?
Thank you so much,
Amy
Adobe Employee
April 27, 2020
Hi Amy,
We're sorry to hear about this. Please attach a screenshot of the error message that you are getting? Also, have you tried scanning the plugins from the Audio Plug-In Manager (Preferences > Audio > Audio Plug-In Manager)? Let us know, we're here to help.
Sumeet
Hi Sumeet,
It doesn't fix it. It does the same thing, the same error. I have tried to reinstall premiere pro and the error still persists.
But after that, adobe premiere seems to work perfectly fine, it is just boring to see that same error everytime I open it.
Here are some screenshots I take
Peru Bob
Which plugin?
It doesn't specify, just says third party audio plugin...
Jeff Bugbee
Do you have any plug-ins in these directories?
/Library/Audio/Plug-Ins/VST/
~/Library/Audio/Plug-Ins/VST/
Same problem here...
Please let me know if you solve this problem, thanks!
