May 9, 2023 4:43 PM UTC
Premiere Pro - Using too much memory 100GB+
On the Premiere Pro 2023 version, I am experiencing high memory usage. There's about 3 TB of footage/photos/music in my project...the memory usage will grow to be as much as 100GB. This issue has been replicated onto a new laptop. My previous laptop of 16GB, would crash while working on my project. I haven't experienced a crash yet on the new laptop, but the memory usage is still going very high. Please, let me know if I can provide any other information to help find a solution to this.
Laptop specs - Macbook Pro i7 CPU 32GB RAM M1.
Michael GrenadierCorrect answer
Jun 4, 2024 5:14 PM UTC
@warb how did you change the frame rate to be constant? Is it in the sequence settings or for each individual clip?
shutter encoder seems to be the best way to convert from variable frame rate to constant frame rate while also transocding to an all i-frame format like prores...  HEVC is heavily compressed and not an ideal format to edit with.
https://www.shutterencoder.com/en/
May 9, 2023 11:58 PM UTC
Hi Morgan,
Sorry for the memory issue. It sounds like what we refer to as a "memory leak." Certainly not normal.
Can you tell us any more about your project? Is it one with a lot of clips in it? What kind of video clips are these? Are they from a camera or a mobile phone? Are they screen captures? About the still images: are they oversized? Have you updated the project across multiple versions? Are there an undue amount of effects applied? Since it's not really normal to see a project in this state, It is hard to diagnose an issue like this without some background about the media and the workflow you used as you worked on the project. Let us know any details you may have and I hope we can help you.
May 10, 2023 3:13 PM UTC
Thank you for reaching out! I answered the questions as best I could.
There's lots of clips in my project, it's an hour long timeline.
As far as types, anything you can think of, .mxf, footage from at least 2010, both phone video/photos to sony FX6 camera, etc.
There are no screen captures as far as I know. The photos are mostly phone photos or downloads from instagram, barely 1080p and some are professional. The project has only been worked on in 2023 version and has been updated to 2023.2. Not a lot of effects applied, some light color correction, few audio filters. Mostly, de-click.
Peru Bob
May 10, 2023 3:29 PM UTC
Peru Bob
May 9, 2023 8:01 PM UTC
Try creating a new project and import the old one into it.
May 9, 2023 8:54 PM UTC
Yes, tried that. Unfortunately, it didn't work. Seems to be stabalizing around 150GB...is this normal?
Peru Bob
May 9, 2023 10:16 PM UTC
No, that is not normal.
Peru Bob
May 9, 2023 6:02 PM UTC
quote
By @Morgan29803041oxel
If you mean hard drive space, and not memory (RAM), then 100 GB may very well be normal.
May 9, 2023 6:22 PM UTC
I believe this is referring to RAM? I'm not sure.
Peru Bob
May 9, 2023 8:02 PM UTC
Yes, that is RAM.
