Premiere sends my clip's audio to track 6 (and it won't move) HELP!
  • August 25, 2017
  • 2847 views
Hello, my name is Melu, and im having a problem with Premiere.
I drag a video recorded on Mirillis Action! (just with those Action! clips this happens) and i can move freely the VIDEO but not the AUDIO. It's like stuck.
The audio of the clip just won't move! I tried changing the audio presets from "Use Archive" to "Stereo" and "Mono" and all the things there, but nothing.
Please, if someone knows how to fix this, i would appreciate it so much!!!
Best regards, Melu
Correct answer melud96464522
I didn't press anything, it just changed D:
Things dont change on their own
You cannot put the 5.1 clip which is now in A6 in A1, A2, A3, A4 or A5.
Please, i want to turn this like it was before, tell me how. What do i have to press??
I dont know how it was before
Make a new sequence from a clip you always use.
Okay, nevermind. I fixed the problem by myself. I converted my Action! file (AVI) to MP4 qith the program "Format Factory" and that was all. Now i can move freely my audio and video. Anyway, thx everyone for your time.
Best regards,
Melu
Audio files sometimes have to go on specific track types.  If no tracks of that type exist, PP will create that type at the bottom.  You can always delete the unused tracks.
I know, but...the problem is that i've been working with those type of files (Action!) since like 2 years ago, and i never had problems till now. I didn't press anything, it just changed D:
Post screenshot of you timeline with the audio tracks expanded.
