Premire pro limits mov rendering to 720
  • January 11, 2018
  • 1424 views
Hi has anyone experienced this?
Using the latest vrs of PP. windows 8.1 64 bit, nvidea gtx 1070 32gig of ram.
When trying to render out vid using mov there are no choices above 720.
    Warren Heaton
    What are the dimensions of your Video in the Sequence?
    What preset are you using when exporting?
    As long as you export to Video dimension that are the same or smaller, you should get good results.
    As far as being limited to 720, that sounds like the Format Preset that you're using.
    -Warren
    Hi thanks but after checking and rechecking PPcc limits my mov rendering to
    only 720
    HI WarrenIt appears these are for Mac.  I'm running Windows. ThanksRandy
    Sent from my Samsung device
    Hi Randy,
    I think the issue is that you chose a DV preset, and DV is always SD (standard definition). Choose GoPro Cineform and that will let you render to HD quality such as 1080p or 720p. As you are on Windows, I would ask why you are choosing to export as QuickTime, what do you want to do with the exported video clip?
    PS - the correct terminology for what you call 720 is actually called 480 (NTSC) or 576 (PAL) - the second number is the one that is used. 1280x720 = 720p HD so when you say you are rendering to 720, that is confusing because the DV export you referred to is really 576 and not 720p which the reader might infer. Makes a difference. 1920x1080 HD is called 1080, not 1920, and so on.
    Thanks
    Jeff
    You might not have all the codec installed.
