TheOtherMartinTaylor
Oct 21, 2022 4:54 PM UTC
Problem editing transcriptions: split & merge buttons don't work. Edit speakers, buggy.
Premiere Pro V23.0.0 - Build 63
iMac Retina 5K, i9, 64gb, 580X 8gb
Monterey v12.6
Transcribing sequences works like magic and is pretty accurate but I have to edit them. The split and merge buttons do nothing anymore. They used to work fine. Sometimes rebooting the machine temporarily solves the issue but they always stop working after a short time.
Also, editing speakers to change the names themselves or to change who a block is attributed to stops working usually after the first edit after restarting Premiere. After closing and restarting Premiere I can usually then edit who said what and what the speaker names are but being able to do so only lasts for one or two edits before I have to restart Premiere again.
Working in corporate video transcripts is an essential part of our process. I love the feature but currently dread having to edit transcripts in Premiere as getting corrections made is so inefficient.
Oct 21, 2022 5:09 PM UTC
I forgot to mention that the editing speakers issue was an issue before I updated to v23. One of the reasons I moved to v23 so quickly was in the hope that this bug had been addressed. The split and merge issue was not as dramatically broken in my previous version.
Ishan Y
Oct 21, 2022 7:51 PM UTC
Hey TheOtherMartinTaylor,
Sorry for the issue, and thanks for explaining it in such detail. It would help us if you could create a screen recording of the problem. We can forward it to the product team to take a look. Was this project started in an earlier version of Premiere Pro? If so, could you reset your preferences, clear the Media Cache, create a new project, and let us know if you're still experiencing the issue with the split and merge buttons?
Ishan
Oct 25, 2022 3:42 AM UTC
This project did get updated from a previous version of Premiere, probably a few versions back and has been updated - I use the same template I've been using for years to start every new project. I did reset my preferences and clear my media cache. I also switched machines to my MacBook Pro i5 opening the same project. It has the same issue. I'll record the issue and then try a new project from scratch later in the week.
