Problem importing a project from Adobe Rush into Premiere Pro
  • July 21, 2023
  • 387 views
Hello community! I recently started using Adobe Premiere Pro, and I'm having an issue. When I import a project from Adobe Rush, the imported video appears very overexposed without making any changes in Adobe Premiere Pro (see file attached). Does anyone have any advice on how to solve this problem? Thank you very much 🙏
Hi Ann. Thank you for being so helpful! I found the problem in tone mapping. Now the clip is perfect 🫶
