Problem importing Premier Element 2019 projects in Premier Pro CC
- September 20, 2023
- 2 replies
- 2357 views
I have follow the procedure to import from Premier Elements 2019 projets in Premier Pro, (https://helpx.adobe.com/ca/premiere-pro/using/importing-sequences-clip-lists-libraries.html ) but I recieve everytime notifications that show some video features missing (transitions, filter, titles, etc), and when I open the projects converted, the text are also missing as is not supported!. Is there a fix for this kind of problems, as we need to convert many projects from Premeier Element 2019 and we have no time re-built all the missing part.
