problem in captured frame
  • December 29, 2023
  • 12 replies
  • 1447 views
after updated to v24.1, the top layer can not cover the lower layers in a captured frame, this also happen when stop playing in the sequence. pleaes help to sol;ve this issue, thank a lot.
i have unstalled n reinstatted it, but the issues remain.
here is the corner pin seeting, i have changed after the update
correction: I have NOT changed the corner pin setting after the update
Mask, nest then apply corner pin to nest.
Please post screenshots (sequence settings, media properties., effects panel, timeline, program window), not sure what the issue is here.
thank you for the reply n help, pls let me knoe if there are more info needed.  thx a lot
