Problem rendering After Effects composition in Premiere Pro
  • January 15, 2017
  • 730 views
Pretty stupid question but Im just trying to narrow down my issue.
Question is: Does one need to render in AE prior to rendering (or exporting) the complete timeline of a PP project when using Dynamic link?
I never have before & never had a problem.
When I go to render or export in PP on this project I get a render error Error compiling movie. Accelerated Render Error. Ive changed renderer to software only but that did nothing. Ive narrowed the issue down to a specific AE composition that I have used a third party (free) preset. (other AE compositions are in the project & render fine)
Version I'm using is CC2017
Any other tips to try would be gratefully appreciated/
Thank you
Todd
Correct answer Tango..........
Disregard.
Ive rendered in AE then imported the mov file into PP. This worked fine.
Tango..........AuthorCorrect answer
Disregard.
