Problem shooting 4k with Filmic Pro
Hi guys,
Im a bit lost with the recording problem Im facing. I am trying to shoot in 4k for quality purposes as Im building a portfolio to try to sell footage to stock agencies. At my current state of budget I can only shoot with my smartphone and try to clean image as much as possible. Usually recording goes smoothly in other light situations, but when a shoot with light aiming directly to the sensor in a low light-high contrast scene, the image "breaks". It produces like a stutter while playing it later. At first I thought it could be my computer lacking speed to playback heavy data but I play it frame by frame on Premiere and the stutter is attached to the image, it seems.
Look some examples:
In this frame level of noise/stutter is acceptable. Below de elbow there is some but manageable.
Few frames later the image "breaks". There are zones of the image that are completely unusuable.
Another example
And this happens if I shoot a sunset or any other similar situation.
I know my recording conditions are not optimal at all but I don't understand what is happen. Is it my playback/graphic card?, lack of codecs. I need some guidance to know how to look it up. I haven't found other facing a similar situation.
Im using FilmicPro app with a Oneplus 3, which is fairly old (2016)
Can someone help me?
