Problem to read a sequence
  • March 1, 2017
  • 522 views
Hi there,
In a project, I use several sequences, and I meet some problem to read one of it, some lags, some slow down.
I can read the others sequences with less difficulties. Precision: the sequence with lags are composed with elements of the others and is kind of the main one with the final cut...
Any idea?
Thx a lot
    kulpreet singh
    Hi fabsim08,
    Are you experiencing lag in playback with a specific sequence?
    FAQ: What information should I provide when asking a question on this forum?
    Kulpreet Singh
    fabsim08Author
    Yes a specific sequence is laging, not the others?
    I'm working on windows 7.
    kulpreet singh
    Import that particular sequence in a new project and check the playback.
    -Kulpreet Singh
