Problem using Essential Graphics Panel - Using Text layer above After Effects template layer.
First of all, sorry if my english is bad. Hope i can make myself clear with my situation.
So, I created in After Effects a few templates to use here in my organization, because we wanted to create a visual identity and using the same elements in the edits would create that feeling.
I created some stuff like logo placements, intros, and all that stuff editable from After Effects and imported into Premiere as Essential Graphics Models.
I did some text backgrounds as well, and there is where my problem appeared. I cannot use any text above those layers!
The preset itself is just a Shape Layer with a position animation so it covers a third of the screen, to add a text to the side of the person. Like in the image bellow.
But the text is to be added alter in the Premiere Pro, using the new Graphic Layer. I then select the Text Tool, and when i click on the program to edit a existent layer or create a new one, it autoselects the graphic layer with the after effects preset and doesn't allow me to create/change the text that is above or below that layer. The only way i can do this is to create the text in another time at the timeline and then rearrange it to where i want it to start. But that's a annoying process to do every time.
watch here - adobe bug - YouTube
Anyone can help me? Is this a known bug?
Thanks!
