agustinv86711249
Dec 12, 2024 8:25 AM UTC
Problem when dragging video from source monitor
I have a sequence with the video attributes that I already changed, before when I double clicked on the clip, and dragged the videos from the source monitor the attributes were maintained, but now every time I want to do that the attributes go back to as if I had not made any changes. Does anyone know what could be happening? Thanks
agustinv86711249
Dec 12, 2024 3:00 PM UTC
I was using it to move to another sequence, but after it started giving me the problem I also tried in the same sequence and the error persists. Regarding your question, I do it from the timeline.
Stan Jones
Dec 12, 2024 2:50 PM UTC
In/out points and opacity mask worked okay.
Shouldn't matter, but you're dragging to the same and or different sequence.
You'd get what you describe if you open the clip from the Project Panel rather than the timeline, but I don't think that is what you're doing?
Stan
