Edoardo Pappi
Feb 5, 2026 8:38 AM UTC
Problem with AUDIO on Premiere Pro 2026: help needed :)
I started yesterday to work on Premiere Pro 2026 and have been experiencing the following issue: when editing with headphones, the audio track on channels 1 and 2 come out only from my left headphone, and channels 3 and forward are muted even if the “M” button is obviously off. Without headphones the problem doesn’t exist.
I have already checked the settings on “Audio Channels”  and it is set to Stereo L+R, so the issue really doesn’t make sense.
I am not experiencing this issue on the 2025 version or on the Beta version, while using the same settings.
Applying audio effects such as Fill also doesn’t work - and even if it did it would be highly impractical to apply an effect to each audio track for this purpose.
I have also checked with colleagues and compared settings - mine seems to be an isolated case.
Is there anyone who could help me fixing this? It is really a drag.
Thank you!
Edoardo Pappi
Edoardo PappiCorrect answer
Feb 5, 2026 1:07 PM UTC
I re-opened it just now and, quite incredibly, the problem solved itself.
I have used the Beta version for one day to avoid it, and maybe the 2026 got jealous.
Oct 10, 2026 1:27 PM UTC
I’m having the same problem over and over. This is a reason why i’m leaving adobe for real. Can’t work, and I have the latest update. Audio is not even peaking, I closed and opened the proyect and works for a few seconds and then suddenly dissappears.
I run windows 11
Premiere pro 26
AMD Ryzen 7 with 32GB RAM
I’m really pissed off adobe you suck at updates and this takes my time off. You should be paying me!
Oct 29, 2026 12:57 AM UTC
Thanks for the message. These are user to user forums and the Adobe product team cannot read your message. Feel free to contact us for assistance if these forums are not helping solve your issue: https://adobe.ly/4BBNrBa - be sure to ask for an agent and be connected to the "video queue."
I hope we can help you there.
Sep 21, 2026 10:23 PM UTC
Hey, this is somehow still not fixed…
It only happens to me when I make a new empty sequence, the best fix I found is to make a new sequence in a different way:
Right click the original clip in the project bin and select “New Sequence From Clip” and just paste your clips in there. Then rename it to whatever you want.
Mar 20, 2026 6:17 AM UTC
Same issue. I just switched to 2026 and all audio is playing in mono. no matter what i do. this is frustrating!
Victor248739623ba2
Feb 13, 2026 4:06 PM UTC
Hey! I’ve had this issue in 26 where the audio tracks seem automatically set to left and right rather than being in the centre by default. Really frustrating, but for me I found panners seem to be just set that way, so you can adjust them manually back to 0 in the audio track mixer section.
I’ve also found that selecting a clip and choosing “create sequence from clip” didn’t have the same issue!
Victor5CD3
Feb 5, 2026 2:15 PM UTC
Hey mate, this is a bug in version 26. I also edit with headphones and had this problem. If version 26 doesn't make much sense to you, go back to version 25.5. Despite some bugs, it's more stable. I've already posted about problems with the audio channels here on the forum; the Adobe team is evaluating them to make the necessary corrections.
Build CPU Ryzen 5700X,64 GB ram,Nvidia geforce 5060 Ti 16 Gb,SSD nvme 1tb + ssd sata 2Tb HD Disc 2Tb Win11 24h2
Edoardo Pappi
Feb 5, 2026 2:54 PM UTC
Have you given 26 another try? I’ve just tried again today and the bug is disappeared.
Victor5CD3
Feb 5, 2026 3:52 PM UTC
Yes, my friend, this bug sometimes disappears, but it comes back if you keep opening and closing the project.
Feb 5, 2026 10:35 AM UTC
Could we have a screen shot of your sequence audio settings, your audio hardware settings and your Audio track mixer.
Edoardo Pappi
Edoardo PappiAuthorCorrect answer
Victor5CD3
Mar 20, 2026 4:02 PM UTC
Because it's a bug, this problem comes and goes; it hasn't disappeared completely. The solution I found helps when the problem appears, but it hasn't disappeared because it's a bug and intermittent. Sometimes it doesn't appear, and other times it appears out of nowhere.
