Problem with audio patching and track
  • November 18, 2022
  • 424 views
Hello All
A client have asked me that they require the timeline to be one continous timeline whilst i had bunch of nested sequences and sometimes clips in the timeline. I highlighted everything and tried to make a nested sequences of my entire timeline but the results are a disaster ... strangely the audio patching no longer works and doesnt correspond  with the  correct track and I cannot move the audio for one of the nested sequences to the track above and only to  the track below...
Correct answer Richard M Knight
It looks like the nested sequence was made as a 5.1, you may have to re do it as a stereo. You cant change the audio settings of a sequence so you may have to copy and paste to a new stereo one. Just be aware you will lose any track effects or automation if you do this.
It looks like you are trying to move a 5.1 track to to a standard track.
is there a way around this ? i dont know why it has turned into a 5.1 track to begin with
Richard M KnightCommunity ExpertCorrect answer
