problem with copy and past between two different sequence
  • February 20, 2017
  • 281 views
Hi everyone.
When I copy a clip, or part of a clip, from a sequence and then I paste the copy clip into another sequence and try to move it, Premiere completely stop working until I forced exit.
The crash happens almost every time I make a past a copy between different sequences.
in the exact moment when I force the exit, the clip seems to be in the correct position but then the software crashes, warns me about a fatal error and tries to save the project.
it’s a very serious problem because I work with projects with many footages and every time I reopen the project I lose a lot of time waiting for loading.
I hope I explained the problem clearly.
(i must says that premiere CC17 crash also when i try to copy and paste text in the title panel, but this for now is a minor problem)
i work with:
iMac (27-inch, Late 2012)
3,4 GHz Intel Core i7
16 GB 1333 MHz DDR3
NVIDIA GeForce GTX 680MX 2048 MB
All the footage are placed on a Qnap Nas where i enter through our internal network.
thanks
    Vidya Sagar
    Hi Tommasom,
    Have you tried the recommended steps? Please let us know the status of the issue.
    Vidya
    Peru Bob
    I suspect Jim's 3H is the problem.
    It's entirely possible that someone else might be able to offer a less drastic solution than mine, but in the event that doesn't happen and you really need to get things working, I have very high confidence that steps 3H and 4 will solve this issue.
    Jim Simon's Premiere Pro Troubleshooting Guide
