Problem With Creative LUTs and Curves Under Lumetri Color, Layer of White Fog?
Hello.
Adobe Premire version: 22.4.0 (Build 57)
Computer/OS: PC, Windows 10 Version 21H2
GPU: NVIDIA GeForce GTX 1660 SUPER
To recreate this problem, I have a video clip and an adjustment layer spanning the whole clip.
Under the adjustment layer, I've made color adjustments to the Basic Correction, Creative and Curves sections under the Lumetri Color panel.
Initially, my previously saved project, I had a LUT selected.
When I attempt to change the LUT to a different LUT, there is this white foggy layer added to the frame that I know shouldn't be there.
Here is how I know it shouldn't be there.
When I click to preview other LUTs (looks), the white fog is still there.When I go back to the originally saved LUT (before I made any changes), you'd expect to see the original frame and look, but you get the white fog layer still.
Here is a screenshot with a frame-by-frame comparison view after I initially open the project, make no changes and click on a preview to a different LUT:
Notice there is no difference between the two frames as I have not selected the new LUT.
When I select a new LUT, you can clearly see there is a foggy(?) layer added to the image (I don't know
how to describe this).
Lastly, I attempt to select the original LUT, but still, the white foggy layer is there and you can clearly see the difference between the two frames:
The only workaround I have is to close the whole project and open again.
