Problem with key Alt+mouse wheel for stretching sequence
  • March 18, 2024
  • 500 views
After I use the alt+wheel key to stretch the sequence window, the mouse wheel stops working to move around the sequence. I have to click to activate the sequence window to continue working. This happened after the last two updates. Any suggestions how to fix it?
Correct answer Ron Rigler
@Евгений31584029iyw6, this issue should be resolved in 24.5 beta 10. Thank you for reporting the problem.
Ron Rigler
Ron RiglerCommunity ManagerCorrect answer
Thank you. It's just beta version problem.
Kartika Rawat
Hi there!
Thank you for reaching out. I'm not able to reproduce the issue. Can you let us know the version of Premiere Pro and the OS you're using?
KR
Moved to discussions
