Problem with keyframes and speed modification of a video
  • June 25, 2021
  • 5 replies
  • 2395 views
Hello everyone, I have a problem with Adobe Premiere Pro, I am editing a video in which I put slow motion with the pen to adjust the speed, but when I want to put an effect or simply that I want to move or enlarge the video with the effect "transformation" I can not put a key frame, if for example I put a video at 100% scale and I put a keyframe at 120% scale there will be no movement just because I put a slow motion, on the other hand when I don't modify the speed of the video, the movement is done. How can I fix this? Please help me, it's important.
Correct answer Peru Bob
Right click on the clip and choose Nest. Apply the speed change within the nested sequence created.  Then apply other effects to the nested clip in the main sequence.
Peru Bob
Théo5CC3Author
OMGGG thank you so much you save me !
Peru Bob
You're welcome.
