Problem with multicam playback
  • January 31, 2025
  • 5185 views
I have 5 angles of footage of a figure skater routine.  They are all 4k.  Two Canon R5, Insta360, GoPro, and iPhone cameras.  I have made proxies for all the footage.  I have them in a multicam and I'm trying to watch it to select the angles to show.  There are parts where the video just stops playing or the fps is like 1 or 2.  I saw a YouTube video that said the audio was causing a problem so I clicked solo on one of the audio tracks, but that didn't help.  I'm on Windows and in Task Manager Memory is like 36% and CPU, Disk, and GPI are all under 6%.  Any ideas on what I can do would be appreciated.  The video is only 4 minutes long.
My Computer Specs
i9-13900K
64GB RAM
Nvidia Quadro A4000 video card
Samsung T7 connected to a Thunderbolt port for the video
Correct answer PaulMurphy
I found out the clip that is giving me issues.  It is the clip that was shot with an iPhone.  I can play the two Canon R5, the GoPro, and the Insta 360 cameras and it works good.  Once I add in the iPhone angle is when it acts up.  The media properties of that file are below.  Any suggestions on what I should do?
Offline: User Requested
Media Path History:
M:\Figure Skating\Jerome iPhone\IMG_8742.M4V
/Volumes/T7//Figure Skating/Jerome iPhone/IMG_8742.m4v
Proxy Media
File Path: W:\Figure Skating\Jerome iPhone\Proxies\Night 1_Proxy.mov
Type: QuickTime Movie
File Size: 5.36 GB
Image Size: 1280 x 720
Frame Rate: 59.94
Source Audio Format: 44100 Hz - 16-bit - Stereo
Project Audio Format: 44100 Hz - 32 bit floating point - Stereo
Total Duration: 00:16:12:40
Pixel Aspect Ratio: 1.0
Alpha: None
Color Space: Rec. 709
Color Space Override: Off
Input LUT: None
QuickTime Details:
Movie contains 1 video track(s), 1 audio track(s), 0 closed caption track(s), and 1 timecode track(s).
Video:
There are 58360 frames with a duration of 1001/60000ths.
Video track 1:
Duration is 0:16:13:38
Average frame rate is 59.95 fps
Video track 1 contains 1 type(s) of video data:
Video data block #1:
Frame Size = 1280 x 720
Compressor = Apple ProRes 422 Proxy
Quality = Most (5.00)
Audio:
Audio track 1 contains 1 type(s) of audio data:
Audio data block #1:
Format = 16 bit - Stereo
Rate = 44100 Hz
Compressor = sowt
Timecode:
Timecode track 1 contains 1 type(s) of data:
Timecode data block #1:
Start Time = 00:00:00:00
Reel name =
It looks like your original media has a variable frame rate (VFR), while your proxy is using a constant frame rate (CFR). This mismatch can cause playback and sync issues in multicam editing. To avoid these problems, I recommend converting your original media to CFR before creating proxies.
For more details on working with VFR media in Premiere Pro, check out this guide:
How to Work with Variable Frame Rate (VFR) Media in Premiere Pro
What are the specs of your proxies? Specifically, their resolution and codec?
For optimal performance, you should use a mezzanine codec such as ProRes, Cineform, or DNxHR. If you're using ProRes, try adjusting the playback quality by clicking the Settings button (wrench icon) in the Program Monitor and selecting Auto-Adjust Multi-Camera Playback Quality.
Avoid using H.264 for proxies, as it is will create a playback bottleneck with multi-camera.
Additionally, if your iPhone footage is recorded in Variable Frame Rate (VFR), it may cause playback issues. Converting it to Constant Frame Rate (CFR) before editing can help ensure smoother performance.
lvthunderAuthor
I used the ProRes half-size preset when making the proxies.  So I guess they are around 1080p.  I'll check for sure when I get home.
lvthunderAuthor
I converted the original clip to ProRes 422 and it resolved the issue.  Thank you so much Paul.  One more question though.  What would you recommend I transcode footage in the future to?  The original file is 8.28GB and the ProRes version is 276GB.
