Problem with old SONY XDcam importing clips into Premier Pro newest version
  • November 17, 2023
  • 257 views
Hi there,
My problem is the newest Premiere Pro can't import my old Sony XDCAM clips properly. It gives zero beginning for every clips. I have tried many ways to import but the clips still start with zero.
The Premiere Pro 2020 can handle the approx. 15 years old sony XDCAM clips in a right way.
The other clips for sportcameras, photocameras etc. are fine, only the xdcam's clips the premiere pro 2024 cannot "eat".
I using MacBook Pro 16 GB Sonoma 14.0 to edit.
Has anybody a solution idea for this situation?
thx,
Kristian from Hungary
Hi @krisztiankadlecsek,
I read about your problem. I heard about this situation. As I understand it, the latest version does not support "spanning" for certain formats in v.24 and Macs running Apple Silicon. It is a feature that relied on Rosetta, which has been deprecated. https://helpx.adobe.com/premiere-pro/kb/premiere-pro-for-apple-silicon.html
Sorry about that!
