Problem with premiere pro cc
DESCRIPTION OF PROBLEM
My problem is consistent, ever since I have downloaded the software it was slow I have to wait a few minutes in every click of a button.
From the start when I'm dragging a video to the timeline I can't see it over there until I press play and the bar that shows where I am in the video doesn't move ever.
it doesn't matter what kind of footage I'm trying to edit.
Furthermore, when I'm trying to edit the speed or scale of the video it doesn't respond at all.
COMPUTER INFO
- OS: Windows 10.
- Processor: Intel I7 - 8750H.
- Installed memory: 16 GB.
- System type: 64 Bit.
- Graphics Card: Nvidia 1050 Ti.
HARD DRIVE INFO
PC401 NVMe SK hynix 512 GB.
PROJECT INFO
- Premiere Version: Premiere Pro CC 2019 v13.0.
- Footage: Canon EOS 5D MIV, 1920×1080, 60fps, about 15 seconds length.
- TRT of the timeline: about 5 minutes.
- All production audio files are on a separate drive as the footage.
- Current project file size: 108 MB.
FAILED FIX ATTEMPTS
- Removed all video effects.
- Created a blank new project and imported the entire old project.
- Restarted computer.
- different types of footage in the software.
Thank you for your help.
