madnessgraphicspoland
Problem with render - green noise witn VR Digital Glitch Effect
  • January 11, 2018
  • 2110 views
I can not deal with rendering the movie, I've been doing it for a few hours. No effect. In Premiere Pro CC 2018 (Windows 10, Intel I5, GTX 970) it's good when exporting a single frame (screenshot) is good, but in every possible configuration on the rendered effect - VR Digital Glitch - I get green noise from pixels as you can see in the movie from 0:24 and same from 0:38.
I have current drivers.
Please Help.
Correct answer madnessgraphicspoland
I found an irregularity, it turned out to be a value in the filter's Noise setting. I do not know why it generates it in green, but setting it to 0 has settled the matter.
HOLY HECK YES! Thank you so much! Setting the Noise strength to 0 didn't effect the actual product BUT removed the green artifacting from my end render! I appreciate you so much!
joergst
oh man, thanks! had the same problem
madnessgraphicspolandAuthorCorrect answer
