Problem with source monitor losing ability to do in and out points
  • May 10, 2023
  • 4 replies
  • 493 views
For whatever reason, the UI in my source monitor messes up and I'm no longer able to see the scrub bar or create In / Out points (See screenshot). I have to reboot the program to get it back, but it ends up messing up again after not too long. I've had this problem pop up pretty regularly for a year+ now.
Premiere Pro - Ver 23.3.0 (build 61)
14" Macbook Pro
Apple M1 Max
32GB RAM
OS Ventura 13.3.1 (a)
ShamgarAuthor
Sorry, I just noticed these respones (a year later). I haven't had the problem for a while, thank you fo addressing it!
Francis-Crossman
Principal Product Manager
May 18, 2023
Thanks @Ann Bens.  I tracked down our internal bug and it indeed is related to loading audio clips. We have a fix in beta now!
This issue has been around for a very long time now.
I see it mostly on audio clips.
Close panel and open by double clicking on clip in project panel or timeline.
Francis-Crossman
May 18, 2023
@Shamgar are you able to reproduce this bug consistently?  What are the steps to make this happen?  I've seen this myself occasionally but can't reproduce it when I try, making it a very tough bug to fix.  Any help from you would be very appreciated.
