Problems with .aaf import in premiere pro cc
  • January 7, 2014
  • 5 replies
  • 23881 views
So I'm having problems with importing an aaf file into premiere. The weird thing is it was working about a week and a bit ago, then stopped. I can't work out why, to my knowledge nothing has changed but if someone could point me in the right direction that would be massively appreciated.
I'm using premiere pro cc and avid media composer. I'm trying to export from avid and import into premiere. I'm creating an .aaf file in avid and trying to import into premiere. When I press import, the progress bar comes up and gets stuck instantly. I can close the aaf import window, but then it leaves the import files progress bar still up and premiere stops responding completely.
At first it worked fine, within premiere I can still use the aaf files already imported, I just can't import more (I can't even import the files I had previously done successfully). I just can't work out why?
Any help would be massively appreciated,
Jack
    hello, to day i still have the issue of no video import with aaf.
    Is it still an known issue ???
    I have found a Mac solution that seems to work well, though I have yet to figure out how to import the audio tracks... Hope this helps.
    Install Apple's Pro Video Formats at this link here:
    Pro Video Formats 2.0.1
    If you do not have Final Cut Pro installed on your system, follow these instructions to install Pro Video Formats:
    martin-thoburn.com » Install the Apple ProRES codec without Final Cut or ProApps
    Premiere will then recognize Avid MXF files.
    Best of luck,
    G.
    shualiko
    Now if only something could be done in the PC arena...
    I'm able to import AAF from MC 8 with all video and audio in PP CS6, with Windows 8.1 Enterprise.  And I know that I could do it about 3, 4 years ago with MC 6 Windows 7, and PP CS6.
    This is using AMA for all clips in MC, btw.
    No effects come through, obviously, but all edits do, and all clips.  And I seem to always have to create a sequence from scratch and paste the contents of the AAF sequence into it.  But after that it's smooth sailing.  Which is great, because AVID rocks.
    The reason for the copy paste that I wrote about is that the frame size for the sequence is always off.  But all it takes is create another sequence with the proper properties and select all copy paste into the new one.
    If you needed to, you might be able to email your aaf to someone with CS6 and maybe they could convert it to be openable with CC.  I'll have to experiment with that.
    The same error experienced with the our yesterday's test.. currently we have AVID MC6.5 version, imported the generated aaf file from Media Composer to (MAC) Premiere CC version  7.1.0.
    Instead of suggesting to revert to a lower version, can the ADOBE Support team just provide us an update software.
    Kevin-Monahan
    Hi Jack,
    We have a known issue with AAF in Premiere Pro CC (7.2.1). Sorry, but for now you'll have to work around this issue. If you want AAF support, you'll have to install an earlier version of the application. Let us know if you need help with that.
    Has this error with AAFs been corrected in the CC 2014 release?
    shualiko
    Not that I know of, I'm still crashing trying to import an .aaf file
    Is this still an issue with everyone or am I the last one still unable to import AAF into Premiere CC?
