torb123
Sep 23, 2015 9:33 PM UTC
Problems with playback speed (Too fast) in Premiere Pro (Imported files from Nikon D4S and D810)
Hi. I have installed Premiere Pro CC and I imported video files from my Nikon D4s and D810 cameras. During playback, the speed is too fast, and I cannot understand a word due to the speed. Why is this? Is the program mis-interpreting the fps rate? I have tried to alter the speed with shift+j or l, but the basic speed for the clips are just wrong. Anyone with tips for a frustrated new user of this program? It was not an issue with Premiere Elements or Finalcut.
torb123
torb123Correct answer
Sep 24, 2015 3:34 PM UTC
I changed the input from the sound card to none, and that did the work!! Thanks
Radlingmayer
Jul 28, 2017 9:51 PM UTC
Thank you, that fixed my playback problem too, it has been days of searching! nice one!
Jul 14, 2017 4:16 PM UTC
I had the same problem just now, playback seemed to be playing frame by frame and looked laggy.
I tried your fix and it worked, all I had to do was disable and enable my sound playback on windows, nothing really to do with premiere pro?..Wierd bug
Jun 24, 2017 12:46 PM UTC
OSX & 50Fps Captured / Shot footage:
With your film already loaded in the Media Browser:
> Media Browser  > Right click your film >Speed/Duration > type in 50% & Enter...your film plays back at the captured 50fps with the correct audio too.
If you also need the audio in slow mo then:
> Media Browser  > Right click your film >Modify >Audio Channels >Interpret Footage >Assume this frame rate >in this box enter the desired frame rate..so a 50fps captured & then set from default 50fps (correct) to 25fps will be half speed & slooooow etc etc.
I hope this helps...works great for me.
VulcanFire
May 6, 2017 5:20 AM UTC
Please help me. I've done what all you people have done but nothing is working for me. I turned the output to nothing and it fixes it but then is speeds back up again. I don't understand and it is really frustrating to me. I am almost literally pulling my hair out because this is so stressful! Somebody Please HELP!!!
Feb 22, 2022 9:59 PM UTC
Hey! I'm in thesame situation as you were! I have beendriven mad. did you find  a solution?
dummergold
Sep 24, 2015 2:03 AM UTC
and look into Premiere's audio hardware settings
torb123
torb123AuthorCorrect answer
dummergold
Sep 24, 2015 5:18 PM UTC
‌good, you have it solved. I would have to guess as Mac and CoreAudio as with my Windows and MME I am unable to reproduce.
I see a lot of this 'playback too fast' and some playback too slow that gives me same suspicion as to Premiere playing back according to frequency as opposed to correct frame rate.
BartonGarrett256
Sep 24, 2015 1:40 AM UTC
‌Check your sequence settings, of both your clips and the sequence, I suspect the sequence frames per second rate most likely does not match your imported clips.  Usually when you create a sequence the program will use the clip parameters of the first clip pulled to the TL to set up your sequence, and warn you if any new one does not match. Do you think you recorded at 30 and actually recorded at 24? I believe the 810 can record at 24, 30 or 60 frames per second.  There is not just one recording rate.  24 is cinematic, 30 more typical of video and 60 fast action, or used to slow motion down in playback.
You can change the playback speed of an individual clip by right clicking on it and choosing Speed/Duration, but you got bigger issues.
torb123
torb123Author
Sep 24, 2015 3:30 PM UTC
Thanks for your answer. However, the time in seconds during the playback is too fast as well? So its just that the playback plays the files too fast? I have been trying to fix this since yesterday now.
Sep 23, 2015 9:42 PM UTC
moved to Premiere Pro
