Problems with plugins .bundle from Premiere Pro SDK for macOS
  • August 23, 2017
  • 2938 views
Hi all,
I am using:
SDK - Premiere Pro CC 2017.1
Program - Adobe Premiere Pro CC 2017.1
OS - macOS Sierra
After compile Vignette plugin from Premiere Pro SDK, it is not load to Premiere. But Premiere founded this plugin.
In log file: "No loaders recognized this plugin, so the plugin is set to ignore."
Does anyone have a solution to this problem? Please, help me.
Hi Sergei,
Have you installed the latest CUDA Toolkit from nVidia?
I can't even get the example to compile...
getting following error in Xcode 9 with latest cuda toolkit.
nvcc fatal   : The version ('90000') of the host compiler ('Apple clang') is not supported
In general this sdk seems to be a bit 'clunky' at least for someone who is used to programming on a Mac!
Bruce Bullis
Internally, we're using Xcode 8.3.
Not sure what you find clunky...?
