Program Monitor Lags with Scaling & Position Changes - Scrubbing is FAST, Playback is Delayed/Laggy
  • February 14, 2022
  • 5 replies
  • 4575 views
I don't usually post on forums for help.. but this situation requires it. I can find nothing to help me with this issue, I've been searching for a week. I've tried all kids of stuff, it gets pretty weird.
My system:
12900k
RTX 3090
64GB 4000mhz DDR4
4x 1TB m.2 SSDs (no HDDs)
Windows 11
The issue:
When I change the scale/position of a video or image it freezes during playback, and when using the mouse to reposition something inside the monitor it's super super laggy. Primarily when increasing the scale or zooming in on something. What's weird though is that scrubbing over the footage is zippy fast. I can scrub and see each frame perfectly, even faster than playback speed. They're mp4 files, but I have tried creating a low res proxy and it does the exact same thing.
Here's where it gets a little weird though... so after a few days of melting my brain on this I discovered that immediately after tabbing back into premiere, everything works perfect for 2-3 seconds! I can reposition something with the mouse and its smooth as butter!---
My GPU has a lot of coil whine (normal for Strix OC 3090) and I'm using an open air case. If I click and drag premiere or a detached panel around for a few seconds, I can hear the coil whine like it's working the GPU, then I quickly click back in and the coil whine continues for 2-3 seconds during which time it seemingly works perfectly! What the heck.... right? Like premiere decides not to use the GPU or something.
When I google it, all I get no matter the search is various ways to fix lag "10 Ways to Make Premiere Run Faster!!!!" and it's a little annoying to be honest. I have done every single optimization step known to premiere.
Here's what I've tried to fix it:
- all Premiere optimizations in settings (clearing cache, selecting openGL/cuda, scale to frame, disabling transmit, reinstalling, clearing preferences, trying premiere beta, etc.)
- reinstall and fresh install game ready drivers
- reinstall and fresh install studio drivers
- re-seating the GPU
- flashing latest GPU bios
- flashing latest motherboard bios
- enabling/disabling game mode
- enabling disabling HGPU Scheduling in Windows
- Manually selecting high performance mode/cuda in Windows and Nvidia Control Panel
- disconnecting second monitor
- disabling gsync
- uninstalling various other programs
- disabling iGPU in bios
- creating a fresh "new user" in Windows and installing ONLY Premiere
- probably like 10 other things I'm forgetting lol
 It seems to me like Premiere is refusing to use the GPU for scaling or something. Short of reinstalling Windows, I'm out of ideas.
Please obi wan you're my only hope
Vid showing the dragging panel fixes issue for 2-3 seconds - https://youtu.be/VEx__0vSXvk
Same problem here. Is it a bug..?
I checked all the project settings & timeline settings for these two timelines. It's the same.
Did you find a fix?? is it just as simple as our timeline being too full of things that it cant handle even the simplest of tasts? so strange. i really need to figure this out in order to do my job
I hope this fix works for you, but I found my fix. It is the POLLING RATE of your mouse!!!!!!!!!!!!!!!!!!!!!!!!!!!!
If you have a gaming mouse (which I assume you do because of your specs) you must beusing a 1000Hz polling rate. Your polling rate has to be 250 or less.
was really hoping that would fix it but no luck.
i'm really tired of these bugs. It was timeline lagging at 23.1 version and now this is happening to me. Timeline scrubbing is perfect, no lag at all but when i try to re-size or move a clip, it lags like HELL. What i think is, something i use in my sequence causing that (primary suspects are JPEG files) but i'm doing something complicated. I can't re-size every single image in Photoshop or convert every single footage to something else for this software to work properly. It's supposed to handle these things.
*sigh*
i just found that, i was using an adjusment layer which includes "Clip Name" effect in it. That KILLS the sequence. FYI.
robk1233312
Same problem here. Is there a solution to this?
PC specs:
Intel(R) Core(TM) i9-9900K CPU @ 3.60GHz 3.60 GHz
RAM 64.0 GB
samsung SSD 970 evo plus 1TB
Nvidia GeForce rtx 2080 ti 11 gb
I have the latest adobe premiere, the latest windows, and the latest nivdia driver. It's a gaming driver.
aTomician
Double check that integrated graphics is disabled - Win X, Device Manager, Display Adaptor, right click and disable any integrated GPU.  Ensure files are on your local drive.  Have you got a GPU control panel - I have the NVidia control panel where I like to increase GPU capacity and specs for Premiere Pro.
Regards, aTomician
If you disable intel integrated graphics I think you will get worse live playback on h.264 and h.265 in most cases... Intel igpu is very useful for live playback in premiere
Have you tried resizing the images in Photoshop and then importing them as the correct size?
The less scaling you do inside Premiere Pro, the better off you will be as far as resource use.
Additional things I have tried:
- setting mic hardware input to no input
- reinstalling my motherboard's chipset drivers
Hey champ. Did you ever find a solution to the issue?
No... I think it's a feature at this point lol
Now a year later I'm having almost the opposite problem with a 4090 installed. The scaling thing still happens no matter what, but now it's like the UI lags and scrubbing is incredibly slow, but when I press spacebar the file plays immediately regardless of scaling.
