Sep 3, 2025 2:34 PM UTC
Project export path resetting in between exports within the same project
My premiere pro keeps resetting the default export location within my project to the "my documents" folder. Is there a way to change the behavior of export path to be consistently the last path exported from that unique project?
So my issue:
1. Edit video and click "export"
2. Click filepath to reset where I want to send my export
3. Export
4. Make edits
5. See #1 and #2
My question is can Premiere behave in a method where I can skip step 2 after I have initially exported to my desired location as it will remember where I sent the first export?
I want to say this is how Premiere used to behave? I think it changed recently and I've just been dealing with it, but I think at least giving the option would really help me and maybe others too.
I'm on 2023 Macbook pro OS 15.6.1
Premiere 25.4.1 (build 3)
Thanks!
EmerrowAuthor
Sep 3, 2025 2:48 PM UTC
I found out that this is the way premiere does behave, but you have to reset the path for each individual sequence.
Peru Bob
Sep 3, 2025 2:46 PM UTC
