Project not saving both manual and Auto. Saving incomplete and to a new location
  • January 5, 2024
  • 196 views
Auto save was not working despite being set to 15 minutes. I went and found the most recent auto save file. It was missing most of the work I did today. The project had been open for an hour while I was away from my desk and nothing saved.
I began manually saving like a paranoid lunatic as a rebuilt everything I did in the morning. I come back hours later and nothing is saved. Again. After 8 hours and pressing command+S at least a hundred times I have 3 edits to show for it. And those were salvaged from yet another auto save file that was in a brand new folder I had to find.
What on Earth is happening?
I took the salvaged project and saved it under a new name. I can only hope it will save tomorrow. At least manually. I will never trust Adobe auto save again.
If anyone has any idea why this migh be happening please help me.
That is truly bizarre.  Ouch!
But to get an idea of even what to do to troubleshoot, what's your OS? How many drives do you have on your computer? Where are you saving your auto-saves to, and where your manual saves? They should of course be to different drives.
That would get us started.
