Sep 21, 2022 10:16 AM UTC
Project panel in second monitor issue
Hi there!
I'm using a dual monitor setup.
I moved some windows on the second monitor, including the project panel, and then saved the changes to the workspace.
When I create a new Premiere project all the panels on the second monitor are there (because I saved the changes in the workspace) but the project panel is on the first monitor.
This happens all the time with no reason. Every time I have to move it to the second monitor.
Jan 23, 2025 11:59 PM UTC
Hey @Daniele21970012wpz6,
How are you doing with this issue? Have you tried the dual monitor workspace yet? How is it working for you?
