alice_0240
Project tab disappears and will not be visible after closing a project
This was happening to me in the last update of Premiere 25 and after the 26 update.
After creating a new project and closing it, the projects tab will not appear when reopened. It will not launch from the Window drop down. In fact, when I select the project, it will repopulate duplicates that never launch (see screenshot). Neither resetting the Workspaces nor selecting All Panels launches the tab.
The only thing that works is creating an entirely new project and not shutting down Premiere the entire time I’m working.
    You may also want to try resetting preferences:  and restore default settings, close the application and reopen it while holding Alt (Windows) or Option (macOS). A dialog box will appear asking for confirmation to "Reset app preferences"; click "OK" or "Continue". This resolves issues like crashes, lag, or incorrect behavior
    Have you tried resetting the workspace? Window/Workspace reset to saved layout?
    Which workspace are you working with?
