Project will not export the correct colors
Hello, I am having an issue exporting a video for a client, where her main video was shot in the color space 2100HLG, and her outro was in Rec. 709. I modified the outro to be 2100HLG, and the color looked fine on the timeline, and looked fine in the preview in the export tab. However, once I exported the video (exported using the color space 2100HLG, and the sequence was in 2100HLG as well), the outro color changed to be more vibrant than the preview and original file. In the image attached below, the larger image on the right is what I saw in the export preview screen, and the smaller image on the left is what was exported.
I don't understand what the problem is. I've also tried modifying all the footage to rec 709, and that was not a solution. I'm confused why everything looks fine in the Premiere Pro export preview, but when it actually exports it looks different. Please help, I am about to lose a client over this!
