Properties Panel when Editing captions is incredibly slow
This is my first time using captions since the move away from Essential Graphics and this is so frustrating. Completely unacceptable from a "Pro" program. Apparently not an isolated issue, I've found others complain online. Does Adobe just not listen to people? Time and time again I see complaints of persistent problems with their products, going back years, without the problems being addressed and fixed. Quality of Life improvements go a long way for retention. Some video games will fix their problems within weeks and makes most people happy enough to keep using their product.
The Issue
So basically, I have every caption highlighted to edit them all at once. Everytime I try to make a change (move a slider) it doesn't actively move, there is a delay of several seconds while it makes the changes. It is not my hardware, and all my software is up to date. This is only a 16 minute clip. I assume what it's doing is populating and rendering the changes accross the whole clip at the same time rather than just what I'm currently viewing, which is uh stupid for lack of better terms. My timeline is paused. Why wouldn't it just focus on rendering the simple changes paused on my timeline rather than using all my resources to change everything all at once? I do not get how that can be conceived as the better option. I really just don't get how caption changes use so many resources to even cause this issue. It's text! It even happens when I turn stroke and shadows off. I mean how the heck was this properties panel even designed? Was it even properly tested before being forced on Premiere Pro 25?
Windows 11
CPU: 7700X
GPU: Nvidia 4060ti 16gb
RAM: 64gb TForce 6000 MHZ
RAM reserved for Premiere: 51 gb
I have deleted cache files. Set focus on timeline for insert/overwrite edits. Hardware acceleration is enabled.
