Proxies blown out in but footage looks fine
  • December 11, 2021
  • 4 replies
  • 3282 views
I have never tried making proxies before, but am taking a video class where the instructor asked us to.  I am shooting on a Sony A7III. Media Encoder and Premiere Pro are up to date. When I toggle to the proxy, the entire thing is blown out.  I have tried all the different format for proxies and the same thing is happening.  When I toggle back, my footage still looks fine.  Does anyone know why the proxies looking so blown out?
Correct answer Kevin J. Monahan Jr.
Hi Katharineann,
Sorry about that. It looks as though you may have shot the footage in HDR/HLG, and automatic interpretation of the footage kicked in - which is a new feature of v.22. This feature caught a lot of Sony and iPhone users unaware.
Are clips shot in HLG/HDR? If so, you may want to interpret them as Rec709 in the Modify > Interpret Footage dialog box. You may also need to create a new preset for proxies so that they match your color managed clips.
If this is all too much to deal with right now, you can always move back to the previous version of Premiere Pro and work with that until you have worked out all the details of a SDR vs. HDR workflow.
As a Sony user, you should take heed of this new feature - which you may wish to use or avoid (most casual users were fine with the previous workflow). Either way, you have to make a choice moving forward to embrace HDR or to move back to a Rec709 workflow.
Hope the advice helps but come back with any questions.
chrisw44157881
that doesn't reference the proxy issue. unless there's a way to change color management of just proxies, i'm all ears.
First, I might suggest using the Rec.709 profile still for shooting. No one I know is delivering much actual HDR content yet. I would expect that will change over the next year or two but at the moment ... Rec.709 is much easier to work with and deliver.
Next .. yes, some users have been able to get the SDR conform to work with proxies, I wasn't.
But they have a new public beta release that supposedly gets the proxies to work with the Interpret Footage color managment settings of the original clip. I haven't tested it yet, but you might want to check it out.
And you can take projects forth & back between the 'normal' and the public beta versions without difficulties too. Just add the install of the public beta, open there, and see if it will make decent proxies.
That sounds good. Thank you for the feedback.
My reasoning for choosing HDR was because it captures more usable image data in low lighting settings. However, I'm not sure how much of this is translated through once the image data is "interpereted" to rec 709 during editing. My guess was that, as you grade, you can bring up details that wouldn't normally be found by recording in regular 709. For example, details normally lost in the shadows on rec 709 would still be available in HDR footage and, when making adjustments to the image in the 709 workspace, the image data is still there to bring up into the working 709 spectrum.
I'm not sure if that makes complete sense but.. I guess its the reason why I am justifying trying this difficult path.
Would love to hear if I'm incorrect! haha.
There is a problem with the current CM for proxies. I've been in touch with a couple devs, who after testing what I sent them, noted there is clearly a problem.
Premiere seems to make proxies from the original media without linking them to the CM applied to the original clip. Depending on what you or Premiere does to transform or not to either Rec.709 or HLG, you get different issues.
That top image looks like a Rec.709 image. So have you used the Override to Rec.709 option and then used the original clips on a Rec.709 sequence?
If not, did Premiere create a Rec.709 sequence and auto-transform the file to that color space?
What I'm expecting ... is that the original is being shown as Rec.709, but the proxies are still HLG, and therefore being shown as if on an HDR timeline.
I dd not Override.  From what I can tell, Premiere created a Rec.709 sequence and auto-transformed the file.  The original is being shown as Rec.709.  I was able to create a ingest profile for media encoder that takes care of the blown out issue but haven't been able to get the colors to match.  Still playing around with it a bit but may just go back to older version of PP for tonight to get this project done for my class before I spend more time fussing with it.
Yes, I would totally concur with going back to the older version for this project.
Proxies ... seem to be blown right now for some media, and even I haven't figured out a way around that. If anyone DOES come up with a way to create a proxy preset that works with CM -overriden clips, PLEASE post it here!
There's a problem with the 2022 version with proxies and some Log and HLG original media.
Is your original media a log or HLG format? Have you checked the clip properties, or used the Modify/Interpret Footage CM section to change the use of this from something to something? What is your sequence color management (CM) set to, also?
My original media is in a custom picture profile that does use HLG.  Thank you!
Kevin J. Monahan Jr.Community ManagerCorrect answer
Hi Katharineann,
My media was shot in a custom picture profile using HLG3.  Can you tell me please if this aspect of this new feature is something permanent moving forward?
