Quad SDI UHD HDR 50P does not work (Sony BVM-HX310)
  • August 29, 2023
  • 0 replies
  • 115 views
I am not sure if Iam doing something wrong but it seems I can't get a proper UHD HDR signal in Premiere Pro. I am using PP2023 and a Sony BVM-HX310 with a Blackmagic Deckling 4K 12G in quad SDI.
My sequence Settings:
HD HDR 50p works fine, I get a proper HDR signal on my monitor.
UHD HDR 25p also works, no problems at all
As soon as I try to use UHD HDR 50P I only get a SDR image on my Monitor.
I tried the same in Davinci Resolve and it works without any issues. UHD HDR 50P works fine and the monitor instantly recognizes the signal.
Is this a bug? What am I missing here? Does someone on here have the same issue?
Thanks
