Quality problem after exporting
  • April 6, 2022
  • 4 replies
  • 1027 views
Not sure why but after export, the title looks bad and washed. In the editing screen it look sharp and crisp
Hi @PatKenoo7 ,
Can you please try the latest beta build once? We have done some export improvements in the latest beta builds. You can download the latest Premiere Pro Beta build from Creative Cloud --> Beta apps --> Premiere Pro (Beta)
https://helpx.adobe.com/x-productkb/global/creative-cloud-public-beta.html
Please try and let us know how it goes in the beta build. If you still see this issue in beta builds, please share your original footage/Project file & export settings. We will check it at our end.
Mayjain
PatKenoo7Author
Not sure that this will help. I never done that before.
Peru Bob
Jut a guess:
Try a different font?
PatKenoo7Author
Did, but nothing. This is the first time its doing that. The text has some artifact or color degradation
nishu_kush
Can you try switching to Software Encoding instead of Hardware Encoding in the Export Settings and export?
Let us know if it brings any change.
Nishu
Peru Bob
Turn off Maximum Render Quality and increase the bit rate.
PatKenoo7Author
didnt do much more difference
FlyingFourFun
so, what bit rate did you increase it to?  I suspect based on the response; all you did was turn off 'max render quality'.
I disagree with turning off max render quality, there is no impact other than performance, and even then, in rare circumstance such as rescaling video (which I can't tell if you have, as you may have a 4k video dropped into a 1080p sequence with a 1080p export.  If you have in fact done this, keep max render quality on as it improved the rescale math dramatically (hence slower but looks much better).
Details are important, please provided them if you would like enhance your success with this issue.
Peru Bob
Please post screenshots of your sequence and export settings.
How did you make the title?
PatKenoo7Author
I actually bought the title template in adobe stock
FlyingFourFun
First of all, 7mbps for 60 fps video is almost half the recommended bitrate from YouTube; they suggest 12 (if HDR 15).
Recommended upload encoding settings - YouTube Help (google.com)
I would change the bit rate to at least 12, but you can go higher....  It seems you're recording with a Go Pro Hero, which if memory serves me correct is a significantly higher bit that 8, its like 78mps depending on the model.
I look forward to hearing back after you try the recommended settings from YouTube.  To me the text looks like bit rate artifacts, it should be correctable with the higher bit rate.  The way the system calculates where to provided the highest portions of bir rate are based on motion, and the text has the least motion, so it will be starved of the bir rate it needs to keep the edges sharp.  in convinced bumping that bit rate will solve your problem.
