Question Regarding Maximum Render Quality and Maximum Depth
I need to export a huge amount of video for the DVD extras for my film. With maximum render quality and depth selected, it will take an inordinate amount of time. I'm wondering if I actually need them?
The footage is 4K and is being exported to 1080p (DNxHD). Because there is so much video on the DVD these extras are going to be heavily compressed (they are also ungraded).
I can't notice any difference at all when doing a test export between the options. Will it make any difference if I do not select the maximum quality settings for this project?
Many thanks
