Quicktime screen recording w/ soundflower audio routing. Audio video problems Premiere.
  • November 22, 2016
  • 1445 views
I was doing a screen recording via quicktime and used soundflower to route the audio from both the built-in output and internal microphone to quicktime. This was all set up on an iMac. I set up an aggregate device to stream both audio inputs into quicktime. Then I used a multi-output device to monitor what I was recording through the macs audio preference panel.
After I saved the video it will playback from quicktime just fine. The problem occurs after I import into premiere. The audio video is not synced up correctly. I checked the fps and it wasn't the same as the original video file. It was set to 55 instead of 34.
Usually, I can google the answer pretty quick, but I started reading forums and post similar to mine and it started sounding like a codec problem. I ended up downloading media inspector to see what was in the video file and wanted some insight at where my problem is and how I can solve this. I'm a noob when it comes to codec problems because I shoot H.264 with a DSLR and have never had any transcoding problems.
Any help or guidance are much appreciated. Let me know if you guys need anymore info.
* * * MediaInspector for Mac - Version 2.6, build 953
* * * ©2012 by Diego Massanti
* * * MediaInfo Lib by Jerome Martinez
* * * Raw File Report for ChrisLukenbill.mp4
General
Complete name                            : /Users/Ruebin/Desktop/ChrisLukenbill.mp4
Format                                   : MPEG-4
Format profile                           : QuickTime
Codec ID                                 : qt
File size                                : 5.59 GiB
Duration                                 : 12mn 3s
Overall bit rate mode                    : Variable
Overall bit rate                         : 66.3 Mbps
Encoded date                             : UTC 2016-11-14 16:52:18
Tagged date                              : UTC 2016-11-14 16:53:23
Writing library                          : Apple QuickTime
com.apple.quicktime.make                 : Apple
com.apple.quicktime.model                : iMac17,1
com.apple.quicktime.software             : Mac OS X 10.12.1 (16B2657)
com.apple.quicktime.creationdate         : 2016-11-14T09:38:42-0700
Video
Format                                   : AVC
Format/Info                              : Advanced Video Codec
Format profile                           : Main@L5.2
Format settings, CABAC                   : Yes
Format settings, ReFrames                : 2 frames
Codec ID                                 : avc1
Codec ID/Info                            : Advanced Video Coding
Duration                                 : 12mn 3s
Source duration                          : 12mn 5s
Bit rate mode                            : Variable
Bit rate                                 : 65.7 Mbps
Maximum bit rate                         : 768 Kbps
Width                                    : 4 096 pixels
Height                                   : 2 304 pixels
Display aspect ratio                     : 16:9
Frame rate mode                          : Variable
Frame rate                               : 34.509 fps
Original frame rate                      : 25.000 fps
Minimum frame rate                       : 13.761 fps
Maximum frame rate                       : 55.046 fps
Color space                              : YUV
Chroma subsampling                       : 4:2:0
Bit depth                                : 8 bits
Scan type                                : Progressive
Bits/(Pixel*Frame)                       : 0.202
Stream size                              : 5.54 GiB (99%)
Source stream size                       : 5.54 GiB (99%)
Title                                    : Core Media Video
Color primaries                          : BT.709
Transfer characteristics                 : BT.709
Matrix coefficients                      : BT.709
Audio
Format                                   : AAC
Format/Info                              : Advanced Audio Codec
Format profile                           : LC
Codec ID                                 : 40
Duration                                 : 12mn 3s
Source duration                          : 12mn 3s
Bit rate mode                            : Constant
Nominal bit rate                         : 640 Kbps
Channel(s)                               : 4 channels
Channel positions                        : Front: L R, Side: L R
Sampling rate                            : 44.1 KHz
Compression mode                         : Lossy
Source stream size                       : 47.4 MiB (1%)
Title                                    : Core Media Audio
    Correct answer cvid01
    You have a variable frame rate which PPro does not like. Use something like https://handbrake.fr/  to convert to a constant frame rate.
    cvid01Correct answer
