Touri
Re: When using the Project panel, is there a way to prevent it from shrinking when you....
  • August 29, 2024
  • 4 replies
  • 559 views
*I'm not 100% sure of the name, but I will refer to it as  the "project" panel, because it usually has the word, "project" before the file name of your project file.
The issue is when I create a new bin, or delete a few files, the whole panel shrinks to be just big enough to show the files that there. Which can be annoying, especially when I want to drag files into that folder.
Anyway I can prevent this panel from changing sizes on it's own? (see attached)
Correct answer PaulMurphy
This happens because you're working with "stacked" panels. Some workspaces, like the Audio workspace, use stacked panels to save space, which can cause the Project panel to shrink when it has less items.
If you'd prefer the Project panel to stay at a consistent size, you have a couple of options:
  • Choose a Workspace that doesn't include the Project panel in a stacked panel group.
  • Alternatively, click the context menu for the panel and choose Undock Panel, then add it to another panel group that isn't stacked.
For more details on working with panels in Premiere Pro, you can check out this help guide.
PaulMurphyCommunity ExpertCorrect answer
Touri
TouriAuthor
I think I was able to figure out what you're saying....
Thank you, kindly.
Try to change Windows => Workspace
or reset the preferences
Touri
TouriAuthor
Thanks Carlos!
