Really Really jittery video and audio - Premiere Pro CC 2018 issue - pls help
  • January 11, 2018
  • 243 views
Video of the issue actually happening: Premiere Pro CC 2018 issue - YouTube
Sorry, I can't screencap, I just recorded it with my DSLR. So basically, I can render the clip, the problem still occurs, I have installed different GPUs, used iGPU, uninstalled and reinstalled over a dozen times. I've done so much and I'm so frustrated. I got Sony Vegas recently but Premiere is just so much more familiar that I don't want to make the switch. If anyone can suggest anything it would be a major help. Thanks
What are the properties of the source video?
What camera created the files?
If you load a source clip to the Source monitor, is the playback also corrupted?
What are the Sequence Setting you are using?
MtD
Sorry for the late reply
I've tried multiple video types, this one specifically was just a 1080p 60fps clip. I use a 200D. The clip in the source monitor is also corrupted, another interesting thing is that the welcome screen, with multiple cinematic clips of ancient ruins and stuff, is also having the same choppy, jittery playback issue.
Sequence settings:
Thanks
