red .r3d files not importing to Premiere Pro 25.1
  • December 12, 2024
  • 1820 views
Have had no problems importing and running .r3d files in Premiere Pro up until now. Suspect related to upgrade to v25.1.
Mac M1 2020
Premiere Pro 25.1
Both on existing projects that were created and ran fine under all pre-25.1 versions, and on attempt to import into new projectsl using standard protocol through Media Browser, I navigate to r3d files, or folders in which they are contained, and failure message:
"File format not supported."
Cannot figure out why.
Under Media Browser>Directory Viewes "RED" is checked and highlighted.
I re-downloaded both RED Cine-x pro and Red Apple workflow installer. still negative function.
Any advice?
Correct answer Kevin-Monahan
Try starting up Premiere Pro while pressing the Shift key. Choose to delete all the media cache from the Reset Options dialgo box. See if that helps, @ryanp16926081.
Cheers,
Kevin-Monahan
Kevin-MonahanCommunity ManagerCorrect answer
Cheers,
Turns out the command to bring up RESET OPTIOMS dialog is Shift+Option. Clearing the media cache worked! Thank you.
Kevin-Monahan
Awesome. Any key should work, though. Sorry for the hassle!
