Aug 31, 2026 5:52 PM UTC
Renderer is grayed out and only shows “Mercury Playback Engine Software Only.” I have an Intel Arc B570, but Premiere Pro isn’t using it as the renderer. I just installed Premiere Pro today. Please help 🙏
    daring_guidec992Correct answer
    Aug 31, 2026 9:12 PM UTC
    Problem solved
    Last time I did install the latest version of gpu from driver but it Didn't work, but today I repair/ install it again from the driver but this time I checked "clean install" and then install it,  the problem is solved.
    daring_guidec992AuthorCorrect answer
    Problem solved
    Sep 1, 2026 12:51 AM UTC
    Cool. Thanks for reporting back!
    Cheers,
    Aug 31, 2026 6:41 PM UTC
    Hi there,
    Thanks for the post. The grayed-out Renderer setting is expected in current versions of Premiere. GPU acceleration is now enabled automatically, so you no longer need to select your Intel Arc B570 manually.
    I'd also recommend installing the latest Intel graphics driver directly from Intel rather than relying on Windows Update.
    For more information, see:
    GPU and GPU driver requirements for Premiere
    Hope that clears things up!
