replacement for Encore
  • March 27, 2020
  • 9 replies
  • 26624 views
  Since adobe Quinn quit encore I have been looking four a replacement for our DVD menu editing and building. Can someone suggest a replacement, I really need it ASAP
[Title edited for question clarity and future forum search... Mod]
Correct answer Peru Bob
Encore is dead because of third party legal issues and will never be revived.
I use Premiere Pro Elements. Not as robust as Encore but it does what I need it to do. It is also very intuitive.
John T Smith
The current version of PrElements will not create a DVD... I'm not sure, but I think that function was removed after version 2022... but could have been after version 2021
Elwoodjblues1
I know this is an old topic, but I think it's still relevant. Physical media is not dead. Especially after streaming services become more and more expensive and take movies offline at whatever whim and there is no legal way to watch them again. This is a disaster for the customer and the producer behind the films. Physical media makes you independent!
I used to use Encore and have realized several projects with it. I'm currently trying to get back into DVD authoring and am testing various programs. None of them is as easy and intuitive to use as Encore. Please bring this program back!
John T Smith
If you used to use Encore why don't you just install it again?
CS6 will still allow you to activate... IF you have activations available
Elwoodjblues1
Because I can't find my copy of Encore anymore and it would be easier for editing if the program was integrated into the Adobe software package like it used to be.
TMPGEnc Authoring Works 6 will not reincode videos for DVD and Blu-ray if you export the video from Premiere as MPEG2 DVD or H.264 Blu-ray.  The program only works on the PC.
John T Smith
I have the serial number CS6 so I can't verify the possible solution at the end of the message below, but it is claimed there that it is still possible to install Encore and use it via the Cloud, by following the exact instructions in the message from Averdahl... as always with old links, copy the download to an external device
https://community.adobe.com/t5/premiere-pro/how-is-everyone-making-dvd-s-in-premiere-pro-without-encore/td-p/11569623?page=1
John T Smith
Just out of curiosity, I searched and found https://www.scenarist.com/
Lots of good verbage about what the program(s) will do... but NO prices
When I click their purchase link, it goes to a form to send information to then be contacted by a reseller
That may work for other people, but I'm not interested in that kind of product where the vendor can't just post links to places to buy
Dont think you want to know the price.
Dale - TC
I use VEGAS DVD Architect for $99.  It's okay, gets the job done, but I really miss Encore's more intuitive/more polished interface and its tight integration with Photoshop for designing custom menus.
Adobe should make an update to Encore to create 4K Blu-ray discs. I would welcome that. Blu-ray disks are still needed from time to time. I want to be able create 4K Blu-ray disks for clients.
I like Encore but if there are to many licensing issues Adobe could create a new software program that works a lot like Encore. I would like to be able create 4K Blu-ray discs for clients.
Their upper managers don't see the metrics indicating a 'need'. A lot of us disagree, but then ... most of the editors and colorists I know say they don't even have any optical drives on their massive rigs anymore.
neil wilkes
What to recommend all depends on exactly what you are needing to do - is the intended output for Blu-ray or DVD-Video?
All menu editing & creation should ideally be done in PhotoShop (this is how we do it, anyway) and authoring tools should ideally be treated as just that - assembly tools and not editors, otherwise you will (sooner or later) run into serious problems with "ghost assets" due to the abstraction layer nature of all the cheaper authoring tools.
So if you could let me know what you need to do, I will be happy to recommend.
For regular DVD, you will have to go a long, long way to beat Media Chance Labs DVD-Lab Pro 2. This does carry it's own built-in menu creation & layout tools as well as importing a layered PSD as well as separate TIF and BMP files and it really does work seriously well, with remarkably few issues as well as being seriously stable.
There is also a fully functional trial version available as well, and for straight DVD-V I cannot say enough good things about it.
Hi Neil
Does DVD-Lab Pro2 work on a Mac?
Check with the website for that app, they will tell there.
(the other Neil ... )
John T Smith
Both do author Blu-rays but DVD Architect has problems with H.264 so using MPEG2 is a must
Encore alternative http://tmpgenc.pegasys-inc.com/en/product/taw6.html
Also https://www.vegascreativesoftware.com/us/dvd-architect/
Nancy OShea
Nancy,
I personally use Premiere and BlackMagic Resolve for all my video editing. You say you use PowerDirector for DVD authoring? I really miss Encore and got to really dig deep with that app but now that it is gone I am at a loss! Does PowerDirector provide tools that I can create custom menus similar to Encore? I really can't see myself using or wanting to learn a new video editing suite since I have used Premiere/AE since version 1
Nancy OShea
@rsutter9950,
Use whichever video editing software you wish.
I rarely if ever burn DVDs anymore.  Digital downloads and streaming media have rendered them almost obsolete.  Wondershare can make menus and burn DVDs & Blu-rays.
https://dvdcreator.wondershare.com/
