"Resolve Fonts" How to resolve??
  • November 27, 2024
  • 4 replies
  • 2508 views
As you can see from the screenshot below, I have plenty of fonts that are "unresolvable". The question is, how can I resolve this so I dont have this pop up EVERY single time I open up PrP?
I have already gone through and modified the text in the MOGRT files and that seemed to do nothing for me as now those fonts are included on the list.
I wish they would just allow us to dismiss this for good.
Do you happen to have any After Effects MOGRTs in your project? Those can sometimes cause font-related issues in Premiere Pro, since the fonts need to be available both in Premiere and After Effects for the template to render correctly.
Theresa Rostek
Hi @John34495747l9tu,
Sorry you're having some frustration. The dialog box is to alert that fonts are not available on the user's system.
Not all fonts that are named the same will be the same font file. For example, Bebas Neue from Adobe Fonts will be different than Bebas Neue from Google, and different from Font Squirrel. Make sure you have the exact font installed that the ReadMe documentation links to that came with your download. (This will not be the case if you downloaded from Adobe Stock, all Adobe Stock files use Adobe Fonts.)
Without looking at the project file, what I can assume is going on is that there are hidden font layers that use the 5 fonts in the dialog. You can check if you
  1. Open the mogrt in After Effects
  2. Type "missing fonts" into the search bar in the Project Panel.
  3. If it returns any comps, then the versions of Bebas Neue you have are not the specific ones that the project was built with.
  4. To fix, go into the comps, find the offending text layer, you'll know it's the right one when you click on the text layer and it looks like [BebasNeuePro-Extended] in the Character/Properties panel.
  5. Change the font to ones you do have.
  6. Save, export the mogrt, and you should no longer see that dialog box.
Now, if you type in "missing fonts" and the Project panel returns nothing, then we may have a bug.
Let me know which situation is yours after trying the above steps.
Theresa
MyerPj
Thanks @Theresa Rostek 🙂
Harold Silva
Entra al link de adobe fonts y actualiza las fuentes
aqui un link corto de la web de Adobe: http://surl.li/jculjr
Salu2
Harold Silva B.
To resolve that, you add the fonts to the normal font location on your computer. So Premiere can find them.
I have some of the fonts downloaded and installed throughout but Premiere still does not recognize them and still puts the errors out
davef43726944
@John34495747l9tu Did you ever resolve(pun intended) this issue? I also have a project with dozens of mogrts and get the Unresolveable Font screen despite having them installed.
