Right audio channel is slightly ahead of the Left audio channel (Premier Pro CS5)
  • June 1, 2018
  • 292 views
I have recently been editing video's for my current job things have been going really well until...
Basically the Audio channel 1 is putting the RIGHT channel slightly a little bit ahead of the left channel so it make it sound like its echoed. I have tried to pull the audio channel back but because the left and the right are linked together you cannot move them with such ease. This is a problem I have never faced in all my time working with Premier Pro
If someone has every had any problems like this then please could you send some assistance my way.
Thank you
As you can see from the image what I mentioned above
    Correct answer Ann Bens
    I cannot remember what CS5 can do or not do but
    Copy and paste audio in Track A2.
    Do one track Fill with Left and the other Fill with Right.
    Then sync them up.
    Then sync them up.
    John T Smith
    Exactly what is INSIDE the video you are editing?
    Report back with the codec details of your file, use the programs below... A screen shot works well to SHOW people what you are doing - For Windows Internet Explorer press the PRINT SCREEN button on your keyboard, and then do CTRL-V to paste the screen print from the clipboard into a forum message
    Free programs to get file information for PC/Mac http://mediaarea.net/en/MediaInfo/Download
    - when you analyze your file in MediaInfo and post a screen shot in the forum, do so in TREE view
    Unfortunately due to the nature of the video I am not allowed to disclose certain information (I work at the hospital) as this will effect patient safety and wellbeing. I can send you all the codecs and all the relative information but screen shots will be edited to a minimal so you will have to bear with me on this one.
    Thank you for your time
