Dec 28, 2023 3:46 AM UTC
Rode Wireless Pro: Low Audio Levels
 Howdy,
I've been googling a lot on audio for the Wireless Pro/Wireless Go 2 systems. I have both, but since upgrading to the Wireless Pro set I can't seem to get the audio levels correct for my video content. It seems that no matter the settings of the mic/camera when I export the audio and drag it onto my timelines, it is extremely low. I have to amplify it by +20 or so for it to be usable... I have ran tests but no matter what it ends up the same once I drag it onto the timeline in PP or Audition. Luckily the quality of the mic is still pretty good and the audio is still usable after I do a little noise reduction to clean it up. But it's still a pain, because inceasing the gain that much obviously increases the noise floor and creates noticeable unwanted hiss. Not enjoying this workflow and wondering why in the world it's importing so low. 😑
Anybody else experiencing this?
Nov 29, 2024 10:57 AM UTC
Just to make sure. I've had similiar issue might be because the lav mic wasn't completely screwed in. Remove the screw if you want fast plugin without that issue.
Mar 12, 2024 11:42 PM UTC
This confused the heck out of me regarding my brand new Wireless Pro audio recordings stored on the transmitter - no matter what gain adjustments I made to the transmitter using Rode Central it remained about -35db.  The only exception is when I held the transmitter ridiculously close to my mouth and I managed to get it "up to" -25db.  After several calls and emails to Rode Support the answer turned out to be that those gain adjustments are ONLY designed to change if you have the transmitter connected via the 3.5mm mini plug - if you use USB-C connection it doesn't react OR no connection at all.  It's not a disaster since the recordings stored on the transmitter use 32 bit float technology and if you export them that way off the transmitter (and often even if you don't) in post you can raise them to basically anything you want without distortion
Mar 20, 2024 11:59 PM UTC
I just started testing the Wireless Pro as well and I'm having the same issue as Haley34484897i6ec.
For my test, thus far, I've attached a lav mic directly to the transmitter. I've tried Gain Assisst set to Auto, Dynamic and Off. I've set the manual gain to 0 and to -32. I've exported the audio from the transmitter and dragged it off, from folder to folder. All of these settings yield the same result, very low audio levels. Premiere is not the issue. The levels are clearly low when I play the file in various audio/video players on my PC.
Steve360377894aq2, I'm confused by your comment, " in post you can raise them to basically anything you want without distortion." Distortion isn't a concern when you raise low levels, a loud sound floor is the concern. The 32 bit float is to protect your recording from clipping, due to very loud sounds.
Mar 21, 2024 12:22 AM UTC
OK I will take that note but the bottom line here is you can raise your audio gain levels in your editing program and still have great sounding audio - it's interesting to me that Rode opted to lock in such a low db level, i've asked them to send me whatever documentation they have related to this issue, we'll see if I get anything from them to help me better understand the logic and practicalities
Richard van den Boogaard
Dec 29, 2023 5:20 PM UTC
It seems like you're recording at way too low levels. The Rode Wireless GO II Pros allow for 32 bit float recording. This basically means you almost cannot record beyond clipping levels. If you set this device then to -12dB, you are effectively capping it off at the knee. Set the mic to 0dB and see how it then comes out.
I have my Rode Wireless Go IIs (not the Pro versions) set to 0dB or -3dB and the audio comes out just fine.
Dec 28, 2023 10:09 AM UTC
Try this with different (non adobe) software) see if this has the same result (or not)
If it stays low volume, there is some not right with the mic.
Dec 28, 2023 10:08 AM UTC
Does the Wireless pro setting preset match your camera? The manual has instructions about this. If you can use the audio recorded in the transmitter that would be better quality as it is 32bit float.
Dec 28, 2023 4:01 AM UTC
How are you recording that? If you do have the levels set correctly, they should come into Audition or Premiere fine.
Dec 28, 2023 5:31 PM UTC
The mic is set to standard (-12) my camera is at standard (-9).
And I use the 32 bit float. The audio is low on the camera and on the separate mic recording. So I'm kinda puzzled.
Dec 28, 2023 5:34 PM UTC
If you didn't use 32 bit float, what do you get?
I'll bet that's where the "anomoly" comes in.
